Hello, I'm wondering what you consider to be the best program to convert VOB files to other files, whether it be to AVI, MP4 or what have you. Whichever program delivers the highest video quality would be ideal.
VOB files are only one part of the entire DVD structure.
https://www.videohelp.com/glossary?V#VOB
https://www.videohelp.com/dvd#struct
Converting only one VOB of the group usually results in disaster. -
Thanks, I'll try those programs out.
Hi, I use DVD Shrink to edit the files first.
Ripping vobs to convert to mkv in future
By nick1977 in forum DVD RippingReplies: 5Last Post: 19th Nov 2009, 03:32 -
Best Method Convert PAL VOBs to NTSC
By ehmjay in forum MacReplies: 13Last Post: 28th Jul 2009, 15:54 -
By ehmjay in forum MacReplies: 14Last Post: 1st Jul 2009, 22:54 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 10:52 -
VOBs convert to what? to edit in final cut pro...
By tSu in forum EditingReplies: 4Last Post: 16th Nov 2007, 22:07
