    Jul 2001
    Hector Medina
    I read vcdhelper guides to rip DVD's and also read an extensive guide on DVD ripping to VCD on a very complete page on flexion, which recomends to apply a resize filter and a telecine filter (if source is NTSC (?)) on Virtualdub and then frameserve to tmpgencoder. I made a test to compress the d2v created by dvd2avi directly to TMPGEnc12h and I got excelent results (and in almost half the time). It looks good even on a 41 projection TV, for VCD. What is the use of aplying the telecine filter in the process? Am I missing frames or something?
    Thanks!
    Sep 2000
    Northern Virginia
    if your source is 23.97fps and purely progressive, then i don't see any need to apply any telecine filter to reconstruct frames (and fields?) and bump it up to 29.97fps. unless of course your player has a problem with 23.97fps...
    Jul 2001
    Hector Medina
    But what if the source is already 29.97? Well, I think if DVD2AVI reports that the source is NTSC, then it means that it is at 29.97, am I correct? Should I convert to other framerate for VCD?
    Sep 2000
    Northern Virginia
    if the source is 29.97fps, you could apply inverse telecine to get it back to it's original filmrate of 23.97fps (assuming it was 23.97fps originally), but inverse telecine is a tricky thing since not all telecined material is the same. try a "standard" IVTC filter and if you wind up with a smooth, progressive 23.97fps video, then you got lucky and can use that to encode to VCD. otherwise, it probably not worth the trouble.
