My 'QuEnc 0.72' is catching when I try to convert avi (Xvid 1.3.0), does anyone know why?
I could not find 'xvid 1.3.0' to download from xvid.org, does anyone know why?
Media Info of the Avi file:
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 59mn
Bit rate : 1 157 Kbps
Width : 704 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.216
Stream size : 991 MiB (100%)
Writing library : XviD 1.3.0.dev55
Here´s a link: http://www.easy-share.com/1905552640/xvid-1.3.0.%28cvs%29-090605.14.58-vaq-mtk_x86-x64.zip
64 bit & 32 bitLast edited by PageDown; 13th Nov 2010 at 21:01.
Converting xvid movies
By SJRSMITH1 in forum DVD RippingReplies: 1Last Post: 14th Jul 2011, 00:26 -
catching up...Can you recommend a good camcorder?
By gts101 in forum Newbie / General discussionsReplies: 9Last Post: 16th Nov 2010, 04:44 -
HELP! MOV to DVD- Audio squashed to beginning of DVD, catching flight soon!
By wildgeese in forum ffmpegX general discussionReplies: 5Last Post: 17th Aug 2010, 21:27 -
Quenc Settings
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 14th Jun 2008, 20:57 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
