Results 1 to 9 of 9
  1. Hi
    Hope someone can help me. I have a bluray rip on my hard drive, which I have used imgburn to create an iso to play in Total Media Theatre. The problem is the m2ts file contains 2 movie streams, the main movie and a documentary type feature about how the film was made.
    When is the iso is created, the documentary feature is the only movie stream that that is played. I cannot select the main movie as the secondary movie stream. Is there a way to extract the documentary out while keeping the bluray structure?
    On a separate note, I extracted the mkv and audio stream using eac3to but when I play the mkv file in windows media center on windows 7 64bit, all I get is a blank screen. When I move the film along, it still doesnt play at all. I'm using shark codecs and this same thing happens with other mkv files but not all of them!! I'm at a loss as to why only some mkv files dont work and others do!!
    Sorry for the long post - I hope it makes sense!!
    thanks
    Try clown_bd and see if you can strip out the main movie. Or maybe it can't keep the menus though.
    Clown BD BD Copier might work.
  4. Thanks. I'll give them both a go.
  5. clown_bd has done the job. thanks a lot for that.
    Any idea's on the MKV issue??
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    What is the video codec in the mkv? Identify using mediainfo.
    I play all mkvs with mpchc. It has builtin codecs for most video formats.
  7. Hi
    MediaInfo says it is VC-1 (microsoft). The other MKV's I encoded using same method is using AVC. Don't know how that happened!!
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    It's normal. Some blurays are encoded with vc1.
  9. OK. Not sure what has happened with my system, as all my mkv's used to work and now, only the VC-1 encoded mkv's have stopped working. Been researching this more and it seems like this issue happens a lot with window media center. There doesn't seem to be much hope to get these working though.
