Hi,
I was just curious as to whether there were any ways ic ould speed up the encoding of my 1080i raw captrue streams to xvid - the current method i have at the moment works ok - i was just wondering whether there were any speed imporvements one could recommend, in terms of the avs script.
I currently use the following:
For example i heard perhaps if i convert the colour space to YV12 or somethign like that, it coudl speed things up?Code:LoadPlugin(\"C:\AVISYNTH\DGDecode.dll\") LoadPlugin(\"C:\AVISYNTH\TIVTC.dll\") LoadPlugin(\"C:\AVISYNTH\UnDot.dll\") mpeg2source(\"c:\test.d2v\") crop(0,0,1920,1080) HorizontalReduceBy2() LanczosResize(640,Height) TFM().TDecimate() VerticalReduceBy2() LanczosResize(Width,352) Undot()
Any suggestions would be greatly appreciated.
Thanks in advance!
Mpeg2Source() should be putting out YV12 already. You can use Info() to verify.
I'd probably use a BilinearResize() instead of HorzontialReduceBy2().LanczosResize(). The latter will probably be over sharp (moire artifacts, halos, buzzing edges). Same for the vertical resize. Yeah, I know, people love over sharp video.
I'm not sure Undot will be doing much of anything after all that downsizing.
I hope this a telecined film source, not interlaced video.
If the video isn't real sharp you may be able to get away with:
crop(0,0,1920,1080)
SeparateFields()
SelectEven()
BilinearResize(640,352)
TDecimate()Last edited by jagabo; 12th Sep 2010 at 07:36.
Software titles that speed-up processing?
By snafubaby in forum Video ConversionReplies: 3Last Post: 28th Mar 2011, 22:34 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
720p vs 1080i - which is best?
By snadge in forum DVB / IPTVReplies: 19Last Post: 31st Aug 2009, 18:19 -
1080i to what ??
By David97 in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 07:55 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 16:25
