Hey everyone, I'm new to these forums and I'm having a particularly frustrating issue I really hope can be solved.
After reading this thread https://forum.videohelp.com/threads/267852-Trying-to-Fix-a-Huge-Corrupt-avi-File!
I found I have the exact same problem this person did.
My issue is I was recording something and will not be able to re-record it. The program I was recording crashed just before I could halt the recording software. The file is 13.5 GB in length. I know this must be doable somehow because a couple of the repair tools I tried such as ASF-AVI-RM-WMV Repair gave me the first 7 minutes of the video intact yet they won't give me any more than that; the filesize seems to be limited for some reason.
I also know the video should be intact the whole way through; I even tried converting to mp3 format and got the full hour's worth of sound intact.
Now again from reading the aforementioned thread, all of the fixes he tried I tried as well and I ran into the exact same issues aside from one difference: upon trying to use VDub I got an extra error. After it attempts to reconstruct the missing index block and I try to play it, I get:
Error decompressing video frame()
VirtualDub cannot decode 4:2:2 Motion JPEG frames with image widths or heights that are not multiples of 16. Please install a third-party Motion-JPEG codec.
I tried downloading one of thes codecs but somehow I don't think it's solving the problem.
Any help at all would be greatly appreciated!!
Results 1 to 13 of 13
The internal MJPEG decoder was off, though I don't think it was using the one I downloaded....for some reason with Windows 7 I can't get any codecs I download to show up in Vdub...but that's a completely different story, and something I tried to fix a while ago and couldn't.
How exactly do you use ffdshow to encode a file? -
Encode? You select ffdshow as the encoder. Then in the ffdshow config you select the Encoder tab, select the codec, and adjust its settings.
Forcing ffdshow to be the decoder is more difficult. You may have to remove all other VFW MJPEG decoders from the system.
Windows has two video subsystems: Video For Windows (VFW) and DirectShow. Generally, programs that use one can't use codecs for the other. VirtualDub uses VFW.
Are you running 64 bit Win7? That introduces another bunch of complexity. Under 64 bit Windows, 64 bit programs can only use 64 bit codecs, 32 bit programs can only use 32 bit codecs. Installing 32 bit codecs often requires special installation procedures (or else the install themselves in the 64 bit section where they don't work and 32 bit programs can't see them). -
Corruption means that that there are gaps in the file. Usually, these are filled up with zeroes. What happens while downloading, is that in the beginning, the file claims the space it needs, for example 100mb. When the dowload is let's say 3 percent complete, there 3 mb worth of real video, and the rest is zeroes. you could try to open your corrupt file with a hex viewer, like Lister. If you see a lot of zeroes, you know you have to redownload it.
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
If you are running 64 bit VirtualDub you need to install 64 bit codecs. If you are running 32 bit VirtualDub you need to install 32 bit codecs. The ffdshow page here has links to both 32 bit adn 64 bit ffdshow builds for Windows.
Some 32 bit codecs need a special installation procedure:
https://forum.videohelp.com/threads/271712-Lame-MP3-Encoder-on-Vista-x64#1723154
You'll continue to get that error until you get an alternate MJPEG decoder installed properly. -
It was not a downloaded file; I'm not sure that you read my original post.Corruption means that that there are gaps in the file. Usually, these are filled up with zeroes. What happens while downloading, is that in the beginning, the file claims the space it needs, for example 100mb. When the dowload is let's say 3 percent complete, there 3 mb worth of real video, and the rest is zeroes. you could try to open your corrupt file with a hex viewer, like Lister. If you see a lot of zeroes, you know you have to redownload it.
Thanks jagabo for all your help so far. I have downloaded the 64 bit versions of both, including codecs. At one point I even installed the KLite codec pack but even those did not show up. I am really unsure as to what I am doing wrong.If you are running 64 bit VirtualDub you need to install 64 bit codecs. If you are running 32 bit VirtualDub you need to install 32 bit codecs. The ffdshow page here has links to both 32 bit adn 64 bit ffdshow builds for Windows.
Some 32 bit codecs need a special installation procedure: -
I did.
I've head rumours of Windows 7 64 bit having issues with this but no conclusive evidence or solutions. -
I happen to have a near virgin Win7 Ultimate installation here. I ran 32 bit VirtualDub and verified that ffdshow did not show up in the codec list (Video -> Compression). 64 bit VirtualDub also showed no ffdshow. I installed 32 bit ffdshow (freshly downloaded from the "direct" link at this web site) from an account with admin privileges (not with "Run as Administrator"). After installation ffdshow showed up in 32 bit VirtualDub but not 64 bit VirtualDub. I then installed the 64 bit version of ffdshow (again, from the link at this web site). 64 bit VirtualDub then showed ffdshow in its codec list.
Note that VirtualDub only searches for codecs when it first starts up. So you have to start VirtualDub after installing the codecs. If you have an instance of VirtualDub running when you install a codec VirtualDub will not see the codec until you exit VirtualDub and restart it. -
Hey again, so your assistance on the 'administrator' mode was definitely helpful, I finally managed to get ffdshow to show up on my Vdub.
So now how exactly to I enable the MJPEG decoder? Vdub still will not open my file and though I have no other MJPEG codecs installed on my system, (other than the one in ffdshow) I still get the
I think this is particularly frustrating because I know my video is intact, I just wish there were a repair program that could give me more than the first 1.5 GB of the file!Error decompressing video frame()
Corrupted/damaged video file .avi
By aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 14:17 -
Help! Corrupted AVI file!
By Rangerbob86 in forum Software PlayingReplies: 10Last Post: 20th Feb 2010, 17:05 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Corrupted AVI File. How Can I Play It?
By GangstaRap in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2008, 17:23 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 15:19
