Hi. Is there a way to embed subtitles on certain parts of a video, then reencode only those parts, eg. function "smarrt rendering" in VDub?
Yes, there are probably a number of ways to do it. It does depend on what type of video codec you are working with, but if you have MPEG2 (or H.264 with newest version) you could use VideoRedo to cut out the portions that you want to embed subtitles into and re-encode those portions (using avisynth + Hcenc/x264 for instance). Then merge them back together in VideoRedo.
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 02:06 -
Editing Integrated/Embedded Subtitles
By Ofelas in forum SubtitleReplies: 3Last Post: 28th Jan 2010, 16:12 -
.avi -> .flv with embedded subtitles using MENCODER
By the_provider in forum Video ConversionReplies: 0Last Post: 28th Oct 2009, 16:38 -
[INFO] Embedded subtitles in .AVI files
By Midzuki in forum SubtitleReplies: 0Last Post: 24th Jan 2009, 00:17 -
English subtitles embedded in VOB files.
By fconolly in forum SubtitleReplies: 4Last Post: 25th Jun 2008, 06:52
