I have one question about information of HD Camcorder of Panasonic ( HDC-SD700 ). It is " 1080/50p , 1080/50i " for signal system. I would like to know what is "50" ? and what is the importance ? Thank you so much in advance for reply.
50 frames or fields per second. Typical for countries which use 50Hz electricity, and/or 50Hz (usually "PAL") video. Main alternative in such countries is 25p for film-like look.
The alternative is 60 frame or fields per second. Typical for countries which use 60Hz electricity, and/or 60Hz (usually "NTSC") video. Main alternatives in such countries are 24p for film-like look, and 30p for something that looks slightly smoother than film but less smooth than video.
According to a quick Google, Thailand is/was PAL with 220V 50Hz electricity, so 1080/50 is the right format for you I would guess.
Hope this helps.
Cheers,
David.
Problem with converting .mts 1080 50i and keeping it 50fps
By gf3user in forum Video ConversionReplies: 10Last Post: 23rd Nov 2011, 09:43 -
Will 1080/50p 28Mbps from Camcorder playable on computer without re-encode
By skydutch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 13th Nov 2011, 11:35 -
HD Video File ( 1080 50P ) from Panasonics TM700
By wisitch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 22nd Aug 2011, 09:45 -
AVCHD Spec Version 2.0 Updated 1080/60p , 50p
By poisondeathray in forum Latest Video NewsReplies: 6Last Post: 8th Jul 2011, 03:45 -
Postprocessing 1080/50i - stabilizing?
By v1ru5 in forum Newbie / General discussionsReplies: 4Last Post: 4th Sep 2010, 15:06
