FOR DV capture in SONY VEGAS, I was told for that format I should set the capture to 3:4
using Sony Vegas 7
right or wrong?
sorry for so many similar postings. I just feel better getting it correct the first time. I'm an audio engineer and I thought that was over the top tech choices, but I see video in the digital realm is way deep as well.
Thanks for all the help people!
I think you mean 4:3 which is full screen. That should be the target ratio for most vhs tapes. UNLESS they were letterboxed. Some are MOST aren't. If they don't have black bars then capture in 4:3. Even if they do have black bars best to capture in 4:3 so you don't get anything wide and squatty or tall and narrow.
You can always crop and reencode later if you do end up getting a letterboxed video - but correctly capture first so its not distorted - that is all but impossible to correct after the fact. - or at least not fun to do once its captured incorrectly.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Help deinterlacing/IVTC'ing VHS material converted years ago from film
By Mini-Me in forum Video ConversionReplies: 25Last Post: 4th May 2015, 13:46 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 09:35 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Digitizing old VHS tapes: Anything Else to Look Out for?
By darkarn in forum RestorationReplies: 6Last Post: 29th Aug 2010, 02:54
