Installed version 8.0.0.5 and I'm not able to use the HD decrypter function. When I click Full Dick option, the popup message says "The Full Disk feature is available in DVD Copy." Is this not a free option in version 8? Thanks, guys.
Results 1 to 10 of 10
Right now I'm just trying to rip anything, but can't get past the pop up screen. Their website still says that feature is "free". I still have the last version 7 update on my system and ripper works fine. Wonder if because I have both versions installed, it's blocking that function of version 8???
I had the exact same problem, GAR. But I updated to the latest beta and (like you) problem solved!
Mine was doing the same - I just reset the free version back into Trial mode to get around it for the short term...
Trev
DVD Fab 8
By eastert in forum DVD RippingReplies: 7Last Post: 4th Jan 2011, 22:14 -
Dvd Fab hd
By durkinjt in forum Blu-ray RippingReplies: 2Last Post: 29th Nov 2009, 17:43 -
DVD Fab 6.0.2.2
By jyeh74 in forum DVD RippingReplies: 4Last Post: 7th Jul 2009, 14:59 -
dvd fab
By kattiemylady in forum DVD RippingReplies: 6Last Post: 28th Dec 2008, 09:47 -
DVD Fab Platinum Frequently Fails, But DVD Fab HD Works. Why ?
By MacPCConsultants in forum DVD RippingReplies: 7Last Post: 4th Mar 2008, 03:39
