I have converted with multiAVCHD a MKV to DVD and the conversion works fine....but, I have add a menu but that is not working.....and to be honest, I do not know how I did it.....
After the conversion everything looks good, but If I play the movie into VLC Player, the Menu starts (very very nice to see) but If I click on play nothing happen!
So something goes wrong....
Is there someone, maybe Dean himself, who can tell us we mabye do wrong? And how to do is that it will play!
Unfortunately, multiAVCHD does NOT produce discs that ALL BluRay players can play. I have a Momitsu BluRay player and multiAVCHD cannot produce a disc that works on my player. The "best" that will happen is that I can produce a disc that starts up and plays audio for what I assume is the main menu, but no video can be seen. I looked on the internet and other Momitsu owners have reported the same problem. I didn't see that anyone has found a solution for our player.
You can try changing some of the settings of multiAVCHD and perhaps you will get lucky and stumble into something that works for your player, whatever it is, but there is some possibility that your player, like mine, is simply too fussy and multiAVCHD can't produce a disc that it will play. -
Did you convert it to SD-DVD (DVD-VIDEO) or to AVCHD DVD?
About momitsu players - no one contacted me about anything. If a user with a problem wants it solved he must post/email either in my forum or at doom9.Laugh and the world will laugh with you. Cry and you will be alone -
multiAVCHD Menu
By catracho2009 in forum Authoring (Blu-ray)Replies: 11Last Post: 29th Aug 2016, 18:18 -
multiAVCHD - subtitles no longer work
By bobo343 in forum Newbie / General discussionsReplies: 4Last Post: 21st Dec 2012, 22:49 -
MultiAVCHD and AVCHDCoder both just don't work with x264 64bit - Why?
By borst_one in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Jan 2012, 11:12 -
MultiavcHD menu problem...HELP!
By digitalfreaknyc in forum Authoring (Blu-ray)Replies: 7Last Post: 12th Jan 2012, 07:06 -
multiavchd menu question
By mysts in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 13:12
