    Mar 2002
    I was hoping to keep the audio as close to the original for my Band of Brothers rips so I decided to give the Flac option a try. The problem is that the audio is far too low. Is there anything I can do to fix this without having to redo the rips?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    You should be able to extract the audio and do a volume boost in a audio editor program. See if audacity supports flac - I don't know if it does but it is a free program so nothing to lose by trying. Then you would remux it into your original video.
    Mar 2002
    Ah I don't know if I want to go down that route as it would be quite a bit of work. Is there a huge difference in quality if I go from dts-hd to the highest setting in ripbot?
