I have created a video CD with Nero 5.5 with menu. It burned ok. But:
1.- I can see the .dat files with Windows Media Player 7 and with compaq dvd player software, but not menu.
2.- I can see the menu with Power DvD but not the files.
3.- I tried in a Sony standalone DVD and do not recognize my VCD, neither an RCA standalone.
<font size=-1>[ This Message was edited by: eroso on 2001-07-25 11:15:38 ]</font>
try windvd, powerdvd doesnt work well with vcd/svcd especially when it comes to menus.
I also had problems with Nero and my Sony DVD. Try using CDRW's. it worked for me.
Jim -
Sony DVD players usually don't support CD-R disks. I expect this is the same voor CDRW disks.
On 2001-07-25 09:49:30, eroso wrote:
2.- I can see the menu with Power DvD but not the files.</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Nero 5.5 doesn't burn menus in a very intellegent (or correct) way so not surprisingly, it doesn't play properly on some software and hardware players.
PowerDVD plays properly menued VCDs just fine.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>3.- I tried in a Sony standalone DVD and do not recognize my VCD, neither an RCA standalone. </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
As others have stated, many DVD players aren't designed to play back CD-R or CD-RW media. You will have to experiment with different brands to find one that works. CD-RW may work better.
Regards.
[/quote]
Michael Tam
w: Morsels of Evidence
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 03:03 -
Power DVD 10 Freeze's When playing H.264 Encoded Movies
By skorpinok in forum Software PlayingReplies: 0Last Post: 24th May 2011, 10:08 -
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 22:15 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 05:35
