Just built a new system: AMD 1090T - 8G RAM - 100G SDD - WIN7 X64 - blah,blah (Its loaded).
Following the guides using MakeMKV is simple and the size conversion with the latest handbrake appears great but just after I start the conversion I get the process stopped requestor.
The machine is running everything else I throw at it flawlessly and quick. Didn't install any extra codecs before or after Handbrake.
Is this a X64 problem with some of the command line apps? or is it just me? Never saw this problem on my older machine.
The machine renders and models 3D like a beast no problems...
Handbrake doesn't need any codecs so it shouldn't be any problem. Can you use it to convert other files without problems?
But I would try shrink with something else, like ripbot264, xmedia recode, uncropmkv.
Or use bd rebuilder to convert from the blu-ray directly to a mp4/mkv.
Mkv to mp4 with handbrake
By hilario in forum Video ConversionReplies: 11Last Post: 5th Feb 2012, 14:27 -
Need Help with HandBrake regarding manual cropping and resize
By FulciLives in forum DVD RippingReplies: 8Last Post: 6th Nov 2011, 02:47 -
Resize and Improve the quality with less time process
By SB4 in forum RestorationReplies: 23Last Post: 31st Jan 2011, 06:13 -
MKV conversions using Handbrake
By havash in forum Video ConversionReplies: 1Last Post: 6th Aug 2010, 01:36 -
HandBrake No Subtitle in MKV
By kinghlg in forum SubtitleReplies: 3Last Post: 16th Dec 2009, 21:07
