Results 1 to 9 of 9
  1. i was tring to use dvdfab to back up my dvd collection, but it keepd crashing so im looking for alternative rippers. i would like to do perfect 1;1 ratios ripping, bit to bit. size isnt an issue, would like better quality so if the movies are 4 or 5 gb each thats fine. a program like dvdshrink will not work, as far as i know that compresses the video and u can disable it. i am storing them and watching them from my pc so format rly isnt a big issues either.
    and ideas?
    Jun 2010
    Out there
    DVD Shrink does allow you to rip a disc without shrinking.
    Under Edit>> Preferences set Target Size DVD to DVD-9
    OR
    After it analysis disc and under Full-Disc mode click underneath DVD Structure the whole disc and set compression setting to No compression. It will save all of the disc without compressing anything.
    Jun 2010
    Out there
    I wonder why DVDFab is not working. It's pretty much the only updated program that lets you rip a disc to PC, other than AnyDVD.
  4. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Just choose no compression on the main display,
    Shrink is way old and although it is still one of my, and a lot of other peoples, most useful tools, it is not suitable for actually ripping newer dvd's because it can not handle most newer copy protections.
    And i am thinking you have some other problem that is making DVDFab crash as i always use the pay version and update it every time there is an update and i don't recall it ever crashing.
    Jun 2010
    Out there
    If you want to maintain the whole disc, including menus underneath DVD Structure click the "DVD_Video" and over next to compression, set to no compression.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by aprillia99 View Post
    and ideas?
    User Error most likely.
  7. I thought DVDfab was free? But mine keeps saying I have reached certain limits & limits what I can do.
    Jun 2010
    Out there
    It is free but only the option to rip the whole disc, not the main movie.
  9. i found out it was crashing because i wanted it to seperate the chapters and it didnt like that.
