Hello All, I am a bit of an AV novice and have always bought region free out of the box players prviously. however, I have just won a Sony BDP S370 and am very impressed with it, but I can't play region 1 dvd's on it......I have seen the hacks using various older OneForAll models but I have just received a OneForAll URC-8350 via an offer from totalfilm magazine. None of the hacks I have found here seem to work with this remote as it doesn't have a "magic" key. can anyone offer a numpty like me any help on how to use this remote to do the hack or give me advice on how to work out how to do it? Thanks![]()
Hi All,
I'm affraid I fall into bubbafurn's case too.
I have just baught a BDP-S370 (DVD region 4) that came with a RMT-B107P remote. It looks a lot less sophistocated than the OneForAll remote that is talked about for the Europe region hack.
I am hoping someone out there might know a multiregion code for the Australian model?
please help
Hi Tancredi, I have the same player and remote as yourself. Did you ever find a hack?
needy also! -
ONE FOR ALL URC 7980 can be set up to unlock SONY BDP-S370
This is from another pg on this site. Its been modified for details of URC 7980.
BDP-S370 should be off while setting up URC 7980.
1. Set URC 7980 to work with BDP-S370. Press MAGIC Press DEVICES repeatedly till BLU is lit. Press 8 for SONY. BDP-S370 should switch off.
Now setup URC 7980.
2. Hold the magic button until the BLU key flashes twice.
3. Press 0533
4. Hold the magic button until the BLU LED flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 00189
8. Hold 1 ( this sets it to key 1 - BLU flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the BLU LED flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Hold 2 ( this sets it to key 2 - BLU flashes twice )
14. Hold the magic button until the BLU LED flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Hold 3 ( this sets it to key 3 - BLU flashes twice )
19. Hold the magic button until the BLU LED flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Hold 4 ( this sets it to key 4 - BLU flashes twice )
24. Hold the magic button until the BLU LED flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Hold 5 ( this sets it to key 5 - BLU flashes twice )
The remote is now programmed and ready to use, to make the BDP-S370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it. Wait until it has completely started & menu has finished loading on screen.
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7980 remote.
3. Put the player back into standby with the Sony remote.
4. Next time you turn on the player it will be region free for DVD playback.
Sony BDP-S370 possible update problems (region change?)
By turk690 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 16th Jan 2012, 22:10 -
How to program remote control for BDP-S370
By Dankriss in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Mar 2011, 03:21 -
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 08:57 -
Sony BDP-s370 hack problem..
By manicjon in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Jan 2011, 09:41 -
Can't play DVD+R on Sony BDP-S370
By sconepanman in forum MacReplies: 8Last Post: 2nd Dec 2010, 15:42
