I'm having problems steaming to my xbox360 as my pc is hardwired on a telus gigaset se567 wireless adsl gateway and my xbox is using the microsoft xbox360 wireless networking adapter, its also 1 floor above me. When I go to network setup it says i may need more bandwidth to watch any kind of moives. My router is on a g network is there anyway to get a better signal as im only getting about 7 out of the 15 bars that are displayed on the xbox setup, not sure what else i can tell you but i would like to stream something that has better quality then a 700mb movie that dosent shutter and look like a bunch of pixels.
If you have to stay wireless get an N router. You will also need to buy a N adapter for the 360. The N adapter for the 360 came out about a year ago or so.
But to be honest the best way to stream is to be wired. That is the only way to be sure you get fault free streaming.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
The length of the cables shouldn't degrade the picture. You may want to look into repeater stations. You should be able to use lan switches to keep the individual runs smaller.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
good to know, would that amount of wire be expensive? if so i know where i can get alot of wire but are the actual ends hard to hook up?
Have a good one,
neomaine
Steaming media player recommendations?
By newtie in forum Video Streaming DownloadingReplies: 0Last Post: 10th Jan 2012, 20:08 -
Sony camcorder USB steaming as a webcam
By bharath in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 17th Dec 2011, 10:43 -
m2ts video steaming issue ( plays too fast)
By alolo in forum Video Streaming DownloadingReplies: 1Last Post: 6th Jan 2011, 09:58 -
DVD decrypter steaming
By levick in forum DVD RippingReplies: 2Last Post: 8th Aug 2010, 15:24
