I have a .mov file with specs: 720 × 480, DV/DVCPRO - NTSC
I am trying to convert it to a Flash file (for Website) with ffmpegX. Everythig seems to work well, except the aspect ratio is getting changed. I do I prevent this?
Are you converting to 720x480 or ?
Try convert to a frame size/resolution with 4:3 or 16:9 resolution, like 640x480 for 4:3 or 640x360 for 16:9. -
Experimented with the settings and I did get it to work--clearly a user error! I am not 100% satisfied with the quality, but it's acceptable.
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 20:25 -
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 18:55 -
How To Maintain Proper Aspect Ratio?
By Bonie81 in forum Authoring (DVD)Replies: 4Last Post: 2nd Sep 2010, 20:23 -
How can I maintain the Aspect Ratio in MeGUI?
By Newtype in forum Video ConversionReplies: 2Last Post: 1st Feb 2010, 10:06 -
DVD to Quicktime .mov / Aspect Ratio Problems with DVDxDVPro
By accumulator in forum MacReplies: 3Last Post: 22nd Sep 2008, 07:45
