I'm trying to convert a 720p recording of the world cup final I made with my TV tuner card and I'm wondering if there is a way to maintain the 59.940 framerate. Every conversion tool I've used changes it to 29.970 and the resulting video doesn't look smooth. Is it even possible? thanks in advance.
Results 1 to 9 of 9
DVD-video doesn't support 60p
The only way to keep the temporal information (smoothness) is to convert it to 720x480i60 (i.e. you have to convert it to interlaced DVD)
You can do this conversion in avisynth , I'm not sure if any of the easy-to-use-1-click-converters do this properly, or allow you enough control
e.g.
Code:DirectShowSource("video.m2ts") AssumeFPS(60000,1001) #just in case frame rate is off a bit LanczosResize(720,480) AssumeTFF() SeparateFields() SelectEvery(4, 0, 3) Weave() -
Thanks , I searched everywhere for an answer and this info was very helpfull.
BTW, I assumed you meant "regular DVD" , because if you had a blu-ray player , you could playback 720p60 on DVD media (make an AVCHD disc with multiavchd or avchdcoder)
Top left hand corner of every page, "WHAT IS",
https://www.videohelp.com/dvd
A standard dvd video has very specific standards. -
If I can just add: if you are just going to DVD there is no need to convert 720p or even 1080p for that matter if you use an authoring software that accepts these formats and the codecs and containers they use. For example DVD Flick will take both of these HD resolutions and make a SD MPEG-2 file in a VOB container (plus the IFO and BUP files) ready for burning.
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 20:58 -
convert .mkv with non-standard frame rate
By Conrad007 in forum Video ConversionReplies: 2Last Post: 20th Jan 2011, 12:50 -
mkv to dvd (frame rate)
By robinmishra in forum Latest Video NewsReplies: 1Last Post: 9th Apr 2010, 09:27 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15 -
Is there a program that can safely convert variable frame rate videos?
By darkzero297 in forum Video ConversionReplies: 1Last Post: 17th Jul 2007, 21:01
