My friend copied some vhs tapes to his hard drive and would like to burn them them to a DVD. They are in .mpg format. Can .mpg files be burned to a DVD or do they need to be converted to a different format first? If they need to be converted what format would be best to convert them to and what program could he use to convert them? Thanks.
You can just burn the mpg as data files on a dvd and many dvd divx capable players will play them fine.
But I guess you want a real dvd-video. Then use a dvd-authoring application, try free apps like guifordvdauthor, dvd flick, dvd styler. -
[QUOTE=Baldrick;2016566]You can just burn the mpg as data files on a dvd and many dvd divx capable players will play them fine.
But I guess you want a real dvd-video. Then use a dvd-authoring application, try free apps like guifordvdauthor, dvd flick, dvd styler.[/QUOTE
I tried to burn mpg files as data, but Nero does not recognize it.
What burner do you use?
Burn MPG file onto DVD
By geek2330 in forum Newbie / General discussionsReplies: 15Last Post: 2nd Oct 2007, 08:51 -
Is it better to burn a VIDEO_TS folder or a MPG file?
By geek2330 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2007, 16:54 -
Please help - >6gig mpg file 2 hr video - need to burn to DVD
By patplh in forum Newbie / General discussionsReplies: 17Last Post: 15th May 2007, 16:16 -
Trying to burn a mpg video file to DVD
By bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 14:22 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
