    Jun 2008
    What is the fastest way (but still reasonable good quality) to convert a windows AVI video (dv 720 x 480 16:9) to a format acceptable by itunes to sync to ipod touch 3rd generation?
    I tried using the h.264 encoder in adobe media encoder. It works, but is very slow. On a 2.8Ghz quad core PC, even setting to CBR it still take 1 hour to encode about 40 minutes of video. Surely there's a better solution? Free solutions preferred.
    If you have a graphic card with cuda hardware encoding support you can try it, like Badaboom.
    Or else try any ffmpeg frontend like the very basic ipodme.
  3. Member bat999's Avatar
    Feb 2008
    Oct 2007
    has to be xmedia recode with presets for ipod.
    amazing front end for ffmpeg, ultra fast, no adverts, no junk
