Results 1 to 12 of 12
  1. Hello,
    I'am living in the Netherlands and use cable internet. My cable internet provider can open the mentioned website but I can't.
    I use the tool "ping" on www.svcd2dvd.com . The ping statistic for 217.194.210.110 are:
    4 times the same message: time-out by assignment
    Package: sent = 4, received = 0, lost = 4 (100% lost)
    A frend of my has adsl internet connection and can also open the website. His ping result is a lot different see below:
    Answer from 217.194.210.110: bytes=32 time=34 ms TTL = 118
    Answer from 217.194.210.110 32 40 120
    Answer from 217.194.210.110 32 34 118
    Answer from 217.194.210.110 32 41 120
    package: sent = 4, received = 4, lost = 0
    I turned of firewall and virus scanner did'nt help either. Thus far, as I know it's the only website I can't...you know the rest.
    Try a tracert www.svcd2dvd.com from the command line/command prompt/cmd. Copy and paste the result.
  3. Originally Posted by Baldrick View Post
    Thank you Baldrick for your advise I wonder have'nt I done that already? Please your assistence.
  4. [QUOTE=Egbert-Habes;2016844]
    Thank you Baldrick for your advise I wonder have'nt I done that already? Please your assistence. Egbert-Habes
  5. Originally Posted by lordsmurf View Post
    Thank you Lordsmurf for your solution but it did'nt work.
  6. Originally Posted by Baldrick View Post
    It took me a while to find out what you mean just discard my last reply the result is: I see the same message endlessly "time out by assignment" and finaly "The trace is done". No other words or numbers in between.
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you actually paste your result (or attach a screenshot):
    Tracing route to www.svcd2dvd.com [217.194.210.110]
    over a maximum of 30 hops:
      1    28 ms    <1 ms    <1 ms  home [192.168.100.1]
      2     *        *        *     Request timed out.
      3    22 ms    21 ms    21 ms  10.1.3.234
      4     *        *        *     Request timed out.
      5     *        *        *     Request timed out.
      6    31 ms    26 ms    27 ms  linx-2.hostinguk.net [195.66.227.23]
      7    28 ms    27 ms    28 ms  cust2-sov.lon.core.as33968.net [217.194.208.21]
      8    36 ms    36 ms    36 ms  ftp14.hostinguk.net [217.194.210.110]
    Trace complete.
  8. Click image for larger version
ID:	3432 Crissyboy, Translation "Bij opdracht" means "by assignment"
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Looks like something is not routing properly after cust2-sov.lon.core.as33968.net ..... I will raise a ticket with the hosting company and see what they can do.
  10. Is there any news about the website Crissyboy I still can't open the site?
  11. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I have submitted a ticket (in the last day or two).... I will keep you posted as to their response.
