    Sep 2010
    Hi all!
    I'm new to DeShaker and VirtualDub. It works fine on most of my videos, but this one is a tricky one.
    Its a cheap cam attached back on an airplane, so its very shaky. You can se horizontal errors all over the image, and DeShaker does not seem to understand how to correct it.
    I have 2 movies here, one is short, and then the full. If anyone can find a way to make DeShaker to work with them, please reply
    Best regards,
    Andreas
    SHORT: http://www.msfk.nu/movies/19_sept_2xbogsering_ralley_okomp-2.avi
    LONG: http://www.msfk.nu/movies/19_sept_2xbogsering_ralley_okomp.AVI (original video from camera)
    Camera used: http://www.kjell.com/?item=50728
    That's not something Deshaker can fix.
  3. Member 2Bdecided's Avatar
    Nov 2007
    Use a camera without a rolling shutter!
    You could look at the rolling shutter solutions being developed for AVIsynth over at doom9, but I don't know how good they are.
    Cheers,
    David.
  4. NewBlue Stabilizer has rolling shutter fix. You may want to try a demo of it. Sony Vegas Pro 10 also includes stablizer with rolling shutter fix.
    http://www.newbluefx.com/stabilizer.html
  5. Originally Posted by Wile_E View Post
    You probably haven't looked at the footage. No way that stabilizer will fix the rolling shutter jello.
    I uploaded a smaller xvid version, 100x smaller than the uncompressed version in case people don't want to download a big file
