I ripped The Lord of the Rings Trilogy recently and decided I wanted to use flac for the audio. On my computer I'm set up through a S/PDIF with the single co-axle cable going to my surround sound. When I encode audio with AC3 and 640 kb/s I get audio played through all 6 channels. However, when playing a movie with an audio encoded with flac, I'm only getting audio out of the left/right and LFE.
I have Classic Media Player set up with the FFDshow audio filter.
I've screwed around with settings within ffdshow, but have been unsuccessful. Mostly because I really have no idea what I'm doing. I have the mixer set up to handle 3/0/2 - 5 Channels with LFE checked. Under output I have all the boxes checked for Pass-through (S/PDIF, HDMI).
My main guess is that my receiver doesn't decode a flac encoded audio file properly or something. The only way I can hear it from all channels is if I check the box for AC3 (S/PDIF encode mode) which I think basically encodes the audio on the fly to AC3 and whatever bitrate I give it (not ideal as I want the lossless audio).
Is there a setting perhaps that I'm just completely missing? Or perhaps a different decoder I need installed (currently using libavcodec).
Any ideas or suggestions anyone has would be much appreciated. I apologize if this is in the wrong thread, but it seemed logical to me.![]()
Results 1 to 1 of 1
Windows 7 Professional 64 bit -- Intel Core i7 930 (2.80ghz - not OC) -- 6gb triple channel ram -- 2 500gb hdds and a 2tb hdd
Playing flac. files using ffdshow and Media Player Classic
By Cunhambebe in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2012, 22:57 -
How do you create a FLAC with multiple songs inside?
By Nagashi in forum AudioReplies: 7Last Post: 25th Dec 2011, 22:00 -
MKVmerge switches speaker channels when remuxing mkv + flac
By tmacd in forum AudioReplies: 0Last Post: 12th Nov 2010, 16:02 -
DVD record multiple channels?
By bobful in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2009, 20:10 -
Recording multiple TV channels at the same time
By Namocol in forum Media Center PC / MediaCentersReplies: 14Last Post: 16th Nov 2008, 08:56
