Alright guys, I'm fairly good with computers, and I'm just getting into dvd's and that sort. I had some problems getting a vcd i made earlier to work. Could anyone suggest the easiest way to make my own picture cd or vcd, and with what programs to use (freeware). My dvd player says it can play both vcd and svcd, but apparenty it said "SVCD 2.0 required" and "turn on PBC". So, any sugestions?
http://www.vcdhelp.com/burnmpg.htm
Tse the above link, then scroll down to the last section.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
