Since I upgraded to vers 8 I can't seem to do a full disk DVD rip anymore?
There is a pop-up "The 'Full Disk' feature is available in DVD Copy"...? Huh? Is there no longer the free ripping functionality?
EDIT: Meh forget it. I upgraded to 8.0.0.8 beta & it's back to normal!?
Results 1 to 10 of 10
I believe there was a bug in 8.0.0.5 which lead to the inability to use the free version that was resolved in later betas.
I am still using 8.0.0.5 on 5 different machines and i have not had that problem ?
Been on vacation a while but am realizing now that the option I want that is giving me problems is the ISO rip. I haven't tried the folder rip yet but by all outward appearances it may still work.
I'll be testing it empirically shortly but does anyone know offhand if WDTV will play TS folders? -
There are several versions of the WD player. I have 1st generation player for USB. The later generations may be different. But on this player you are definitely better off with an .iso image. It will play the vob if you select it. But it will want to quit after the vob is done instead of continuing through the movie. Just use Imgburn to create an iso image file on the HD.
Select the "write files/folders to disc" option. As soon as it sees it's a VIDEO_TS folder it will ask if it should change the file system type as appropriate to a video DVD. Just click OK or Yes. In the Output Menu select Image instead of device and just name the file with an .iso extension. It should pick up subtitles and all that but I don't think it shows the DVD menu.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
In a DVD VIDEO_TS folder not all files are playable. Also I think subtitles work better with .iso. I'm talking about DVD .sup muxed in subtitles, not an .srt file stuck in the folder. Unless they updated something in spectacular fashion, the .iso works better than just a VIDEO_TS folder.
For movies with audio in your native language and no forced subs it may not matter. But I watch a lot of foreign films and it matters enough that I either do an .iso folder or use MakeMKV to convert to an .mkv file.http://milesaheadsoftware.org/
I can't access the free DVDFab HD Decrypter anymore - Why?
By JohnnyBob in forum DVD RippingReplies: 25Last Post: 16th Mar 2014, 19:36 -
DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?
By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28 -
DVDFab 7 HD Decrypter
By burnmaster in forum Blu-ray RippingReplies: 3Last Post: 9th Apr 2010, 09:11 -
Is DVDFab HD Decrypter no longer free?
By paulnsf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2009, 23:09 -
DVDFab Decrypter
By HacktheHacker in forum DVD RippingReplies: 11Last Post: 26th Feb 2008, 00:10
