I have a Samsung BD-C5500 player and 90% of my AVI's, MP4, MKV video files are out of sync when playing back. The audio is basically about half a second behind the video. DVD & Bluray play fine.
I've done some research and cannot come up with a solution. Re-encoding a ton of files is not an option I want to take. The settings on the player are of no use too.
Anyone got a solution to this? I have no receiver at the moment. The audio is basic RCA Left Right going into a TV.
Is there a receiver I could purchase that would speed up the audio a fraction?
Any suggestions appreciated.
You might try to upgrade your firmware version, check in Samsung's web page, /Support and select your specific model to check if there is any new firmware version. They usually include a pdf file with the steps to do it. Not sure if this would solve the problem.
I own a Samsung home theatre (HT-Z320) and shows the same issue that you just described when playing a DIVx movie through the USB port. Have not tried DIVx discs. DVD plays fine too.
Region free code for Samsung C5500 not working on US version of players?
By whatz in forum DVD & Blu-ray PlayersReplies: 8Last Post: 21st Dec 2011, 19:31 -
Region free hack for Samsung C5500?
By letshavefun3 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Feb 2011, 22:21 -
Samsung BluRay BD-C5500
By ce6pcm in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jan 2011, 18:23 -
Samsung BD-C5500 Need Help...
By cetrax in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Nov 2010, 19:08 -
Samsung BD-C5500 - messed region change
By GuillermoR in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Aug 2010, 08:22
