hi
just tested some job rendering in avidemux.
I have some kind of weird problem.
The audio-channel isn't synced anymore with the video
how does that come.
any solution
Are you reconverting the audio or using audio copy mode?
What is your video source? Video codec, audio codec, framerate, etc. -
good question
They all have something different.
I will take one with which I have the problem.
I am reconverting the audio
And also I'm trimming the source , I don't need the rest of the video
I was starting with following: WMV
- video codec: windows media video 9
- resolution: 720 x 406
- framerate: 30f/s
- audio codec: windows media audio 2
- channels: stereo
- sample rate: 44100Hz
- bits per sample: 16
This to what I go: MP4
- video codec: H264 MPEG-4 AVC
- framerate: 30f/s
- audio codec: mp3 CBR
- channels: stereo
- bitrate: 128
I also tried to convert it with audio copy
But this won't work.
I suppose it's because of the audio channel that cannot be contained in a MP4 -
I did a second test
same source, same video output, different audio output
- framerate: 30f/s
- audio codec: AAC
- channels: stereo
- bitrate: 128
same problem
avidemux audio out-of-sync problem
By scarlac in forum Video ConversionReplies: 3Last Post: 20th Sep 2010, 11:37 -
Avidemux - DVD/VOB file to MP4/MKV - Audio problem
By prabath_fun in forum Video ConversionReplies: 0Last Post: 7th Sep 2010, 10:32 -
avidemux audio shift problem
By allenn in forum Video ConversionReplies: 0Last Post: 16th Dec 2009, 21:44 -
Audio shift problem in Avidemux
By sir_ken in forum DVD RippingReplies: 3Last Post: 18th Sep 2009, 12:25 -
Avidemux audio problem....
By weatherman19 in forum EditingReplies: 5Last Post: 4th Aug 2009, 17:35
