hello all,
i've been using a pinnacle studio PCTV for some time now to do TV>VCD transfers. it has served its purpose, but now that i have a dvd burner, i want to go TV>DVD, and since the PCTV won't take in more than 352x240, i'm looking for a card that can handle full screen captures.
please make some suggestions for me.
also, my current card is running on a p3/733, 256mb, 40gb 7200rpm hard drive. is this good enough to handle what i want it to do? i have other computers available, but this one is the most convenient to do the work on.
thanks in advance.
Have a budget amount in mind?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
not looking to spend too much.. as i said, i have other pc's available, so that's not a problem. i just want to know esentially what i need to accomplish what i want to do. wouldn't really want to go more than $200 on a new card, but i'm also easily persuaded. :D
For real time TV->DVD, you're going to need much more than a P3-700.
You're looking at a motherboard+cpu upgrade (P4 or AthlonXP) and a new capture card (AIW 7500 is a good deal right now). -
does it have to be TV > DVD?
you could upgrade to more disk space (80gb Maxtor $110 newegg.com)
and maybe a tv wonder.
cap to avi then dvd
cheaper, more options, and better quality via filters etc..
but of course takes a bit longer
setup to capture a lecture?
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 2nd Feb 2012, 15:47 -
XBOX 360 Capture Card (warning, weird setup xD)
By erickek in forum Capturing and VCRReplies: 1Last Post: 6th Jan 2012, 13:36 -
VDub setup for VHS Capture
By HDClown in forum Capturing and VCRReplies: 16Last Post: 27th Apr 2010, 03:48 -
Room for improvement in my capture setup? (VHS)
By Killer3737 in forum Capturing and VCRReplies: 2Last Post: 4th Oct 2009, 15:55 -
Video Capture setup fit for dual purpose? could do with some advice.
By brek in forum Newbie / General discussionsReplies: 1Last Post: 14th Jan 2008, 04:25
