I recently downloaded this program that changes windows theme. The catch was that it only worked for windows vista and xp. I made a gamble by using windows 7. The aftermath- my laptop wasn't that messed up. Just all the file and folder icons were screwed up.
Here's the list of problems
- arrow icons for program shortcuts are replaced with an icon of a cd and box
- folders have a different icons NOTE I already tried using the method of customizing the icon and it didn't work for most folders
- files that have to be opened manually or that are unreadable(EXAMPLE- an srt subtitle file) have a shield icon instead of a blank paper like icon
- local Disk D has a red X mark on it
PS- where can I usually find the folder in local disk C that contains windows icons
- I am usually left to a dead end with 'local disk C_windows_System32'
Your help will be much appreciated
Closed Thread
convert a video.avs to a desktop shortcut that vdub can read [SOLVED]
By vhelp in forum ProgrammingReplies: 0Last Post: 28th Dec 2011, 19:34 -
how do i restore icons image back, for all icons ?
By vhelp in forum ComputerReplies: 2Last Post: 15th Dec 2011, 22:20 -
Windows 7 desktop icons
By dfisher052 in forum ComputerReplies: 3Last Post: 30th Mar 2011, 11:55 -
Remove "My Bluetooth Places" Shortcut On Desktop
By lowlow42 in forum ComputerReplies: 12Last Post: 26th Apr 2010, 10:17 -
Desktop icons constantly rewriting
By cal_tony in forum ComputerReplies: 8Last Post: 23rd Apr 2008, 17:34
