Hey guys, I need help to convert .MKVs to MPEG. I used Total Video Converter to convert 450MB file to mpeg and it showed 2 hours ETA. Does anyone know any fast software or method to do it? MY HDTV only support MPEG-1 and MPEG-2 so that's why, Thanks!
Regards,
Encoding speed is, first and foremost, tied to your CPU and how well the encoder utilises it. Fill in your computer specs so we know what sort of PC you are working with.
ConvertXtoDVD is one of the fastest encoders around, but only outputs a DVD structure. You can then use VOB2MPG to get an mpg file.Read my blog here.
It's not so much the filesize, but the length in time, and also the resolution.
If your MKV has 60 minutes running time, that's not too bad.
MPEG video encoders can be one pass, or multi-pass.
Each pass takes about the same time.
With my setup, each pass is between 1.5 and 2x the running time, using HCEnc.
My PC is rather old, so you should do better.
A two-pass encode lets you choose exactly how big the file will be.
If I don't really care, I use one-pass mode ("constant quality"), as when I want to make a DVD-RW, watch it once.
I don't know how Total Video Converter works, but I guess it's two pass.
Converting MKV to MPEG-4 w/o subtitles
By Forsake in forum Video ConversionReplies: 7Last Post: 12th Jul 2012, 09:43 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
How Convert MPEG To MKV
By noam_7 in forum Video ConversionReplies: 6Last Post: 22nd May 2011, 16:59 -
Convert MKV to MPEG-2...format questions, etc.
By pcombs in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 17:58
