I've done a bit of research and testing re this but can't quite crack it,time as a busy father is scarce!
Basically i wish to create AVCHD discs for playback on blu-ray player from MKV files that are around 8gb in size.
I'm using 8.5gb discs so i can't exceed that size.
Therefore i want to convert WITHOUT increasing file size,happy to shrink it if required (a la dvd shrink) but without detectable quality loss,but ideally a straight conversion retaining original file size would be best .
Maybe i need to create an image file and burn straight to disc with img burn?
Expert help please.
MultiAVCHD is the simplest method to ensure that the video is compliant (most MKV files have been cropped and have to be re-encoded with the correct letterboxing added), and authored correctly. The results can then be burned with imgburn.
Read my blog here.
I'll add (as I did many times in the past) that tsMuxeR AVCHD-disc mode does NOT create 'standard' AVCHD structure. It creates Blu-ray structure (folder/file wise) with a minor change to index.bdmv and that doesn't make the output AVCHD compliant.
Laugh and the world will laugh with you. Cry and you will be alone
Help with BD-P1500 and mkv via AVCHD
By Syco54645 in forum DVD & Blu-ray PlayersReplies: 48Last Post: 10th Oct 2010, 07:12 -
AVCHD to MKV 5.1 Ripping
By amitabhbansal in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 04:33 -
mov to mkv/avchd
By nirbhayn in forum Video ConversionReplies: 1Last Post: 19th Jun 2009, 15:33 -
Converting Mkv to AVCHD
By ranosb in forum Video ConversionReplies: 1Last Post: 9th May 2009, 06:25 -
mkv to avchd trouble
By hazbro1 in forum Authoring (Blu-ray)Replies: 5Last Post: 7th Jan 2009, 12:34
