Hello,
Sorry if this is posted on the wrong section. I am going to buy a blu-ray player for a very good friend of mine, and I have no idea which one to get, especially because I don't own a blu-ray player myself.
My budget is around 150 bucks. I have looked in a couple of places and I have seen that they have some for that price. And they seem to be pretty decent... I guess.
Anyway, if there are any good deals out there, things that I should keep in mind before buying, brands that you would recommend, or any websites with a decent selection, please let me know. Any help would be extremely welcome.
Thanks a lot!!!
Thanks!
I am considering getting this guy:
Toshiba Blu-ray Disc™ Player Model No: BDX2500
From here:
http://www.hhgregg.com/ProductDetail.asp?SID=n&ProductID=37616#page
Looks like a pretty good deal. Thanks again! -
Does your friend care anything about region free playback of DVDs or BluRay discs? If you ask "What is region free playback?" then the answer is "no". If your friend does care about this, since you live in the USA you'll have to look into getting an Oppo or Momitus BluRay player. Note that Oppo requires you to change the hardware yourself to support region free playback. The Momitsu should already be set up ready to go by the reseller.
If your friend cares nothing about this, the only advice I can give you is that I would avoid Sony players. Some people care about playing other file types like Divx, MKV, etc. and Sony doesn't support that kind of thing.
If your friend lives outside of the USA and Canada, I would not recommend that you buy a player here and bring it to them. Long story short - you'll regret it if you do that due to DVD region issues. -
Thanks a lot! My friend does not really care about region free playback. As far as I know, he doesn't own a movie from outside the US. And we all live in the US, so that should not be an issue.
Are there any other brands or places that you would suggest?
Buying new Blu ray player
By imars99 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 26th Aug 2011, 12:57 -
Buying advice - Should LCD TV or blu-ray DVD player have Wifi capability?
By coody in forum DVB / IPTVReplies: 2Last Post: 11th Dec 2010, 11:52 -
Will You Be Buying A Blu-ray Player This Year?
By MOVIEGEEK in forum DVD & Blu-ray PlayersReplies: 32Last Post: 16th Mar 2009, 02:06 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 09:07 -
Sharp BD-HP20U Blu-Ray player worth buying?
By ebenton in forum DVD & Blu-ray PlayersReplies: 11Last Post: 29th Mar 2008, 15:13
