So I've been Recording Gameplay from my 360 and PS3 with my hauppauge HD PVR,
It Records it as .TS which Sony Vegas(Vegas Movie Studio HD Platinum 10.0) wont open I get an Error Saying "none of the files Dragged to Sony Vegas could be opened"
So I was wondering if there was a way I could change it without lowering the Quality AT ALL, to something Sony Vegas would Recognize or maybe there's something I could do to Sony vegas so it will Open the .TS files
I also tried the Decoders on Wintv7 (MPEG and H.254) and it still said the same thing in Sony Vegas.
The Media Info-
if you need Pictures Error Reports or any other Details let me know, I really need to fix thisCode:Format : MPEG-TS File size : 4.66 GiB Duration : 59mn 13s Overall bit rate : 11.3 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 59mn 14s Bit rate mode : Variable Bit rate : 10.3 Mbps Maximum bit rate : 20.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.166 Stream size : 4.27 GiB (92%) Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Duration : 59mn 14s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Video delay : -79ms Stream size : 163 MiB (3%)
Thank you for any help!
Sony Vegas problem
By francisco-drm in forum Authoring (DVD)Replies: 1Last Post: 18th Nov 2011, 07:16 -
problem with sony vegas
By buffaloboyy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jan 2011, 21:06 -
Sony Vegas Webcam Recording Exception Error
By ventrino in forum Newbie / General discussionsReplies: 0Last Post: 16th Jan 2011, 09:50 -
Problem with Sony Vegas
By Beibin in forum EditingReplies: 4Last Post: 20th Jul 2010, 22:28 -
Problem with Sony Vegas 7
By DeaDudeA in forum EditingReplies: 6Last Post: 26th Jul 2007, 21:42
