I just have a quick question I should two videos of the same thing from two different angles at the same time. But since I didnt hit record at the same time the time codes dont match up. Are there any plugins I can use that would automatically sync the two videos together based on the audio?
I've never used it myself, but I've heard quite a few folks that use PluralEyes
http://www.singularsoftware.com/pluraleyes.html -
it's not hard to sync multiple vids. easiest way is to play it and adjust one until you don't hear any echo in the audio while playing both at the same time. lining up the peaks in the audio timelines also works.
AVI audio becomes out of sync in Vegas Pro 9.0
By Thunderhead2772 in forum EditingReplies: 5Last Post: 25th Nov 2011, 17:39 -
Sony Vegas Pro 10 - video/audio out of synch after render
By Acester47 in forum EditingReplies: 4Last Post: 1st Jul 2011, 14:06 -
Sony Vegas 8 Pro - No audio stream for MPEG-2 video
By tarrickb in forum Newbie / General discussionsReplies: 10Last Post: 9th Jan 2010, 15:45 -
Resyn audio with video using Vegas Pro
By 7saigon5 in forum EditingReplies: 0Last Post: 28th Nov 2009, 08:22 -
Quality of Vegas Pro when putting audio with video??
By ingeborgdot in forum EditingReplies: 2Last Post: 12th Sep 2009, 09:29
