  1. Member Benjy's Avatar
    Oct 2009
    Canada
    Recently appeared on the marked new type of BDs ~ 3D format .iso.
    What soft/s are necessary to be able to see internal files (.m2ts) and what soft can split and extract them???
    I have a XP SP3 , Daemon Tools Pro but these are not enough....those who have installed Win 7 can easy process these files...
    any idea or help ???
    Someone tell me I need AnyDVD for seeing those files as .m2ts....
    Who knows and has experience in this area?
  3. Member Benjy's Avatar
    Oct 2009
    Canada
    yep , of course.....
    The problem is more complicated than shown at the first view ...As I told above , it is a 3D Bluray disk as .iso file..
    First of all must see the inside files ( as m2ts ) and then to select or split them if you wanna encode ....
    virtual clonedrive is very good to watch the movie in CyberLink PowerDVD , but for spliting files.....no
