How to use Wi-Fi feature in a Blu-ray DVD player to play a DVD movie or video?
I don't really follow your question, as phrased. The player's optical drive will play (locally) a DVD or Blu-Ray disc. Presumably you are referring to streaming ? This feature (e.g., for Netflix) came in with some Blu-Ray player models from Panasonic and Samsung, and seems to be becoming more common. I don't know of any way to play an actual disc to the player from some remote location, using the Wi-Fi. What you can do is set up the built-in networking feature from the player to your router, which involves certain steps depending on the Wi-Fi security for your wireless router, and then "registering" your Netflix account for streaming to the player / location. Other streaming services will have other procedures, but having the proper wireless access to your router will remain a constant.
If that is not what you meant, please give a lot more detail in your question.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
So the Network or Wi-Fi in a Blu-DVD player is primarily just for streaming movies online, correct? Do you know whether a Wi-Fi Blu-ray DVD player can play videos or dvd movies from a PC with build-in Wi-Fi, by the way?
Depends.
If you have a wireless router then most likely yes. You would also need some streaming software (TVservity, PS3MS, WMP under Windows 7). You will be limited by the bandwidth, so you might not be able to stream HD material.
If you just have a laptop with built-in wireless then it will depend on whether or not you can configure that wireless to act as an access point. Some can, some cannot.Read my blog here.
[QUOTE=jman98 Based on your recent posts here, I have to conclude that you just don't believe in ever looking at the manuals that come with your players.[/QUOTE]
Actually I have not bought but searching a Blu-ray DVD player. Your research is just waste of your time, isn’t it? -
Quite a few electronic devices such as BD players have downloadable manuals you can get from the manufacturer. Look under 'Support'.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
35 Mbit/s authored DVD to play on Blu-Ray player???
By meisnerboy2 in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 15:05 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 02:00 -
Want to make hi-def DVD to play in blu-ray player
By amfriedman in forum Authoring (Blu-ray)Replies: 3Last Post: 24th Mar 2009, 21:12
