Hi,
I have a PCI express graphics card but cant seem to find drivers anywhere.
There are a few stickers on the card which read:
CougarLP-10-M04
HP PN: 5189-0459
MS-V110B0801065182
CT:P 9036 0D P1 VL 1G0
There is also a Model number which appears on front and back. this is V110.
there is also a N1996 number printed on the card.
Anyone any ideas what drivers I need for this card - My OS is XP Pro.
Regards
Results 1 to 9 of 9
That is a HP branded Radeon HD 2400 Pro. You should be able to use the standard AMD/ATI drivers.
Can you plug it in (perhaps even as a secondary card), and look up how Windows identifies the card?
HP PN: 5189-0459 looks like a Hewlett Packard part number.
What kind of plugs/ports does it have on the outside end?
Guillemot made graphics cards with the "Cougar" name, but that was in the Win95/98/NT4 timeframe (upto 1999), long before PCI-E was born (2003).
Edit: Never mind, zing269 seems to have found a match. -
Can someone tell me where I can purchase one of these cards? If not, does anyone have a suitable idea for a replacement?
Thanks -
If zing269 is correct:
http://www.amazon.com/Radeon-HD2400PRO-Pcie-256MB-Dvi-i/dp/B000V20FNY
That card is pretty dated. There are better choices. What do you need it for? -
I know there are much better cards out there, but I need to know which one I could replace this with and not have to change the PSU. It also needs to be low profile.
I would look at something like this, you mentioned the card was PCIe but is that 1 or 16. Does your mb support 2.0?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127613Murphy's law taught me everything I know. -
Pretty much any car on this list will be better than the HD 2400 Pro:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709%20600007855%2060...atedMark=False
Be sure it comes with a low profile bracket. For example:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150562
And make sure you have the right power plugs on your PSU. And the right connectors for your monitor.
You can use this site for rough benchmarks:
http://www.videocardbenchmark.net/Last edited by jagabo; 5th Nov 2011 at 19:54.
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
identifying video capture card
By Michael Ray in forum Newbie / General discussionsReplies: 10Last Post: 26th Oct 2010, 22:11 -
Problems with Video drivers after reboot
By Snakebyte1 in forum ComputerReplies: 2Last Post: 5th Dec 2009, 15:17 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Looking for video drivers for my card
By WinSpecToR in forum ComputerReplies: 4Last Post: 19th Jan 2008, 02:47
