Hi I am using AVS Video Editor 4.2, and in the "volume and balance" menu, you can slide the 3 sliders anywhere between 0 to the left and 200 to the right.
And the three sliders are for "Main Video," "Video Overlay," and "Audio Mix" (audio mix = extra audio you have added).
I made a video and I added audio. So I turned the audio of the main video to 0, and the video overlay to 0, but what should I turn the "audio mix" to?
When I tried turning it to the middle - 100, it ended up sounding too quiet when I uploaded it to YouTube.
So I redid it on 200, but now I think it might sound distorted. Or at least the part of my video with voices sounds distorted. I don't know if the music does.
Anyone know what setting it SHOULD be at?
ps: to my question...
Also:
You know the red line that you can move up and down and diagonally in an added audio track...?
If I want that line to just stay straight across, how far up should that red line be....?
Should it be halfway or 3 quarters of the way, or all the way up?
Will all the way up also cause distortion?
Thanks.
-D.
-D.
Results 1 to 1 of 1
help me improve the video quality of my game trailer with avs video editor
By DapperDave in forum Newbie / General discussionsReplies: 4Last Post: 24th Apr 2012, 01:06 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
AVS video editor text problem
By ginny02 in forum EditingReplies: 1Last Post: 15th Aug 2010, 08:14 -
FREE AVS Video Editor less than 4 1/2 hours left...
By tmorrow411 in forum EditingReplies: 2Last Post: 14th Sep 2008, 01:54 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2007, 23:10
