    Feb 2010
    Brazil
    Hi,
    I downloaded a DVDRIP from a Nirvana show: The Reading festival
    The video quality is great, but the audio is a MP3 128 Kbps.
    I found the audio from the same show with flac format.
    Is there a software that keep the video and change the audio to this Flac, both without re-enconding. Or I have to converting to MP3 and change the audio in a software like virtualDub ?
    Thanks. And sorry my bad english
    I don't think so.
    But you can make a mkv with flac audio, use mkvtoolnix, load the avi and flac and make a mkv.
    Feb 2010
    Brazil
    Thanks. Works fine
    I had some HD (720p) music videos. But the audio of these vides is not so good.
    I will use the MKVmerge to join these videos with a flac audio.
