Hello, I am caputuring with and ati card. Using divx5.0 the problem is I drop frames when trying to capture in 640x480 useing the max bit rate. When I caputure using 352x240 at max bit rate I drop none. The real question is what should I do caputure at 640x480 and use less bit rate or caputure at 352x240 and higher bit rate which is best??? Thanks for any help.
Your system specs, please.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
The bitrate doesn't make a huge difference for capturing performance (unless you have a slow hard disk).
If you're using MMC 7.5, you should be able to do 640x480 IBBP with 0% motion estimation without dropping frames on a P3-700 (motion estimation is what kills the cpu).
You might want to consider 480x480 as well, it will look just as good as 640x480 for VHS captures.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 11:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 21:15 -
Please help me stop dropping frames!
By justin81 in forum Capturing and VCRReplies: 28Last Post: 1st Apr 2011, 07:17 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 08:47 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 01:25
