i'm currently using quenc 0.72, anyone know any better?
i mean free converter
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
more efficient = better quality at a given bitrate
I think, multiangle might require closed GOP , but for "normal" DVD's open is always better -
AFAIK, multiangle requires closed GOPS and fixed GOP length.
But if you don't need closed GOPS, don't use them, as poisondeathray mentioned, open GOPS are more efficient.
The reason behind it is, for open GOPS the first B-frame(s) can also use motion information from the previous GOP.
For a closed GOP the first frame after the I-frame is normally a P-frame wich only uses motion information from the I-frame, so compression will be less.
If you want to heavily edit the stream, also use closed GOPS, you can easily cut the stream at each I-frame.HCenc at: http://hank315.nl
standard 720x480 DVD to Avi 720P with free converter?
By MilesAhead in forum Video ConversionReplies: 26Last Post: 26th Apr 2010, 17:44 -
Free MTS to AVI converter?
By cheerful in forum Video ConversionReplies: 5Last Post: 8th Sep 2009, 19:49 -
The best free avi to vob converter
By mmmipa in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2008, 17:28 -
Help with mpeg to avi converter
By ortus in forum Video ConversionReplies: 3Last Post: 8th Mar 2008, 03:49
