...where can I find it for my Mac?
Basically, I have a video that was exported from Adobe Premiere Pro in the pre-CS3 days, which I want to open up in After Effects and Final Cut on my Mac Mini. The file is in *.avi format, and was created using the standard "export" option that supposedly didn't compress or alter the video. It does open, so I know that the file isn't corrupt, but it really doesn't like my Mac, and can't seem to find the codec it needs for Final Cut or After Effects. The file was created under Windows before I had a Mac, but I'd really like to get at it again. Any help would be greatly appreciated.
Finally, I realize that this could go in multiple forums, but since I need the video to run on my Mac, I posted it here. Mods can move this thread if they feel it would be better suited for a different forum.
Specs: Mac Mini (Early 2006): 1.66 GHz Intel Core Duo CPU, 320GB HDD, 2GB DDR2 RAM, Intel GMA 950 integrated graphics card, Matshita UJ-846 Superdrive, Mac OS X 10.5.7 and various peripherals. System runs Final Cut Express 3.5 for editing.
Use mediainfo to ID the codec. Most likely it is DV-AVI or uncompressed (huge file). If DV-AVI, convert it to .dv (a lossless conversion) in Quicktime Pro.
http://www.kiva.org/about
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Pro 2 Help
By slicebogey in forum EditingReplies: 6Last Post: 9th May 2011, 18:21 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
Should I get Adobe Premiere Pro CS4? - Upgrade from Pro 1.5
By vid83 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 18:10
