I would love to get your opinions on the purchase of a DVD ROM for my PC. Also, I would like to find out if it is at all affordable to get a DVD writer for my PC.
What is the latest ?
Thanks,
Jolo
for DVD rom and DVD-R ( my bias against DVD+RW ) would be all Pioneer. I have both, a Pioneer 115 DVD Rom for DVD Ripping, and a Pioner A03 DVD-R ( RW ) for wrting to DVDs. I also have a Toshiba DVD Ram drive but have since gone completely over to the IDE format and no longer using my SCSI devices, the Toshiba being a SCSI device.
Agreed.
Go with a Pioneer slot/tray loading 115 or 116 DVD-ROM and grab the the new Pioneer A04 (DVR-104) DVD-R/W writer.
You'll find less compatibility problems with DVD-R/W than you would with DVD+RW (+R has yet to be tested - but IMHO, it's too little, too late and may just be DOA).
Kusanagi -
You can find the Pioneer 106S (slot loading drive) 16x DVD ROM/40x CD-ROM, as seen here: http://www.googlegear.com/ggweb/jsp/ProductDetail.jsp?ProductCode=701107 or the 116 (tray IDE drive here): http://198.104.184.48/cgi-bin/webdata_pro.pl?_cgifunction=form&_layout=hardware&keyval...ntory.id%3D496
You can find the A04 DVD-R/W writer at many online vendors such as the following (or just do a quick pricewatch search):
http://198.104.184.48/cgi-bin/webdata_pro.pl?_cgifunction=form&_layout=hardware&keyval...ntory.id%3D493
http://www.esbuy.com/pioneerdvr104.html
Good luck in your purchase!
Kusanagi
PAL -> NTSC DVD Writers?
By tac7 in forum DVD & Blu-ray WritersReplies: 4Last Post: 2nd Aug 2010, 21:34 -
Recommendations On Best Pioneer Blu-Ray Writers
By II AnDo II in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Dec 2008, 12:28 -
XP does not recognize my DVD writers as DVD writers thinks they're CD write
By steve1040 in forum DVD & Blu-ray WritersReplies: 5Last Post: 25th Jul 2008, 01:52 -
Better DVD Writers
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 2Last Post: 30th Sep 2007, 13:51 -
@^DVD-Roms wont Read Dual Layer^@
By Varchasve in forum Newbie / General discussionsReplies: 13Last Post: 20th Sep 2007, 19:13
