Hello. I make a DVD with dvdlab pro with 5 different VTS. In a VTS 1 is the main movie, which is with Bulgarian and English audio and Bulgarian subtitles.
By default, the movie should have started with Bulgarian audio and subtitles off. And everything is just fine until I go to some other VTS, where I have trailers. Then when I come back again of the VTS 1 with the main movie subtitles are On. I also have a menu of audio and subtitles settings.
Can anyone help me on this issue.
P.S. In this case I can't put Warning and some logo video, because they are a different VTS.
My experiments continue, but without result.
I put all the videos in one VTS, and when I play main the movie subtitles are off, which is OK. But if I play one of the trailers (which are in the same VTS), and then play the main movie it is with subtitles, without I choose the subtitles from the setup menu.
If this gives more clarity on the issue.Last edited by blajko; 3rd Sep 2010 at 15:37.
It is quite possible that this is a bug in DVD Lab. If you are familiar with command structure you can download your project into PgcEdit (free software) in Trace mode and check command line for the movie. DVD Lab use abstraction layer (register R10 to R15) for its own use.
Overlapping subtitles on DVDLab Pro
By ikarishinji41 in forum Authoring (DVD)Replies: 3Last Post: 18th Jun 2010, 04:06 -
Weird problem importing son format subtitles from TS in DVDLab Pro
By Talayero in forum SubtitleReplies: 1Last Post: 15th Apr 2009, 05:47 -
Subtitles in DVDLab Pro 2
By lorix in forum Authoring (DVD)Replies: 13Last Post: 13th Nov 2008, 15:09 -
make my own default setting in dvdlab pro ?
By pcb in forum Authoring (DVD)Replies: 0Last Post: 13th Mar 2008, 15:21 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 11:16
