1-) file - open -> choose first avi file;
2-) file - append -> choose second avi file;
3-) keep video and audio as copy, format as avi;
4-) file - save - save video.
is working but after finishing the first video has a strange sound
this "strange sound" is like the beginning of the first avi
please help :P
It's correct but that might happens some times. Don't know why.
I would try another tool, like virtualdub. -
i already tried virtualdub but the audio always comes out of sync. -
Avidemux first indexes the audio of the video files if they are mp3 with VBR. You did it correct as sgbd said. Sometimes, Avidemux asks if you want to "unpack packed beatstream" the video part (xvid, etc). I choose "no" and audio is ok.
Or try to demux the audio with Virtualdub with 'Full Processing Mode" and "PCM" (no compression). Save the new Audio file (Menu -> File-> Save Wav).
Then you open this new saved audio file (Audio from another source) and choose a compression like mp3 or whatever you want.
Save the whole file with Video in "Direct Stream Copy"
how to join files in Avidemux?
By FaisalKhan in forum Newbie / General discussionsReplies: 15Last Post: 19th Jun 2015, 11:29 -
Avidemux 2.5.6 Failure to start on some videos where Filters are used.
By ABBrittain in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2012, 10:47 -
How to use Avidemux to join MP4 ?
By Mue in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2010, 10:07 -
MP4s - how to correct them, then join them together?
By extent in forum Video ConversionReplies: 2Last Post: 15th Aug 2010, 15:06 -
Avidemux + YAMB couldn't join my .mp4 files - help!
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 14th Jan 2010, 15:33
