I have a panasonic SD9 i have files recorded to 1080i AVCHD. Id like to resize to a smaller res. However, what ever format i use the outcome never looks as nice as resizing the original 1080i whilst its playing Why is this? The video has alot of motion (cam on a bike)
The only success i have had is going from avchd 1080i to avchd 1440i This maintains the sharpness, which just disppears between frames completely in any other format.
Any ideas people?
Originally Posted by danielbb
Also "resizing" changes the information that is available to be displayed. If you are also lowering the bitrate that will lower quality as well.
What is your destination?
Are you going to a portable device like an ipad or zune or droid phone? Are you making a dvd or a bluray?
You should adjust your expectations to the destination format. If it can only display sd resolution hd won't look as sharp as when it was in its original hd format.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It seems the same no matter what bitrate i select in other formats even if its mahoosive lol.
Is there anyway to use avchd at custom resolution and bitrates?
My aim is to just have smaller videos for archiving and youtube uploading, very important stuff will be left a is. I understand that avchd uses h.264. If i try output it h264 even at crazy bitrates, my sharpness is lost. -
Maybe its going from I to P im not liking. I might try recording to 1080p and the to MP4 see if im happy then
Thanks for your help so far
Reducing loudness and sharpness from recorded movie
By Stief in forum AudioReplies: 3Last Post: 7th Oct 2010, 11:51 -
Maintaining 5:1 Surround
By GaryDZ in forum EditingReplies: 4Last Post: 22nd Feb 2010, 09:38 -
Sharpness in GK
By eliqush in forum EditingReplies: 9Last Post: 4th Aug 2009, 08:54 -
aspect ratio and sharpness
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2008, 12:35 -
Re-Authoring and maintaining 5.1 ??
By pmoscatt in forum Authoring (DVD)Replies: 7Last Post: 2nd Aug 2007, 08:21
