  1. FOLLOWING VIDEO CLIPS LOOKS WIERD OD HD-TV AFTER MAKING A DVD, NEEDS TO BE CORRECTED FOR PROPER ASPECT RATIO, WHILE ALL PLAY NICELY IN ALL MOST ALL MEDIA PLAYERS.
    1)
    Width : 720 pixels
    Height : 400 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    2)
    Width : 640 pixels
    Height : 272 pixels
    Display aspect ratio : 4:3
    Frame rate : 25 fps
    3)
    Width : 720 pixels
    Height : 304 pixels
    Display aspect ratio : 2.35:1
    Frame rate : 29.97fps
    1) HOW TO MAKE ONE STANDALONE DVD OUT OF THESE VIDEO CLIPS FOR NTSC STANDARD DVD?
    2) IS IT POSSIBLE TO CONVERT CLIP#2 & CLIP#3 TO NTSC STANDARD (720X480, 23.976FPS OR 720X576, 25FPS) DVD SIZE?
    Oct 2005
    666th portal
    1) you must know how to turn off the caps lock. please do so.
    2) how long are they?
    3) 1 and 3 might work ok together as a dvd but adding in a pal vid will cause problems.
  3. Clip # 1 = 45m15sec
    Clip # 2 = 55m37sec [ I can shrink or stretch timebase to 23.976 or 29.99 by demux-n-mux, but AR? ]
    Clip # 3 = 25m08sec [ -as you said "1 and 3 might work ok" -- seems OK, I adjusted to proper AR.]
  4. 1) Stretch to 720x480, encode as 16:9 anamorphic MPEG 2 with 3:2 pulldown flags.
    2) This doesn't sound right. Why would someone use a 640x272 frame to encode a 4:3 video? I'll assume it's square pixel and 2.35:1 DAR. Stretch to 720x360, add borders to the top and bottom to bring it up to 720x480, encode as progressive anamorphic 16:9 MPEG 2 at 25 fps, Add 3:2:3:2:2 pulldown flags with DgPulldown.
    3) Resize to 720x360, add borders to the top and bottom to bring the frame up to 720x480, encode as interlaced anamorphic 16:9 MPEG 2 at 29.97 fps.
    Author to DVD.
  5. Clip #1 and 3 are shooted in North America, While Clip #2 is birthday celebration in PAL country.
    Author to DVD.
    Worked!
    Thanks to both of you for inputs.
