VCRs, TVs, cable mouse, cable box problems
(sorry if this is the second time you see this. I had a power outage as I was posting and don’t know if the first message went out or not)
For financial reasons, I am not in a position to upgrade to the latest technology, like DVRs, HD TV and the like, and my current setups will have to last a while longer.
So here is a problem I am having.
I have two Sony SLV-81 VCRs hooked up to two Motorola DCT 2000 cable boxes (and two analog TVs). I wanted to be able to record one channel while watching another, so I downloaded some instructions from a Time Warner website which called for using an A-B switch, and then bought a couple of cable mouse units (IR blasters) from Sony. Together, I have been able to do this – watch one, record another, and also with the cable mouse, change channels automatically to whatever I programmed into the VCR timer.
Suddenly, this does not work anymore. The cable box is overriding the cable mouse’s instructions and not changing channels. I tested this out.
Last channel used, say, channel 4. Timer goes on, selects channel 11, then within a second or two, snaps it back to channel 4. I know the cable box has the ability to allow changes, but the cable company has disabled this feature.
Does anyone know how to remedy this situation?
Thanks for your help -- Judy
Results 1 to 1 of 1
DVR and Cable Box
By pepegot1 in forum DVB / IPTVReplies: 12Last Post: 27th Oct 2010, 19:33 -
PC controlling a cable box (USA time warner cable)
By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 16:24 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Problems copying off my cable box now that I have HDTV
By TheRybot in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jan 2008, 16:29 -
Digital Cable Box, DVD Recorder, Television Hook Up Problems!
By robdawg70 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 30th Jul 2007, 14:35
