Hello, Guys.
Please, I need help.
I always used Nero, to create my VCD's and SVCD's. However, I don't find interesting, to cut the files mpeg's, to create Menus with chapters, in Nero.
I found better, to use TSCV 0.84 Beta Rel2. I get to create Still Menu easily with TSCV. Everything perfectly works.
However, I already tried of everything and I still didn't get to obtain success in Motion Menus' creation. I already read the text of Martini's http://www.personal.psu.edu/users/r/d/rdm186/guide2 (excellent tutorial and of great help for all of us - congratulations Martini's) and other tutoriais on TSCV.
In the previous stages, Setting, Menu, Chapter, everything is Ok. The problem begins after the generation of the file mpv, in MenuGen. TSCV is not getting to convert the file for mpg, in other words, it doesn't get to make that conversion automatically (I already configured Path of Tmpgenc 2.5 - Version 2.53.35.130, cd.bin, etc in Settings). Para to improvise, I tried encoder directly with Tmpgenc, but the quality of the image in the file generated mpg, is terrible.
The other problem, appears in the hour of converting the images jpg, in the c:\tscv\seq. If I choose the option 300 frames, the file jpg seq0000300, it is not generated (he/she sees Log below).
I also noticed that, in the window Log of TSCV, after the conversion, the following mistakes appear:
INFO: Parsing & checking input files.
INFO: Image dimensions are 352x240
INFO: Movie frame rate is: 29.970030 frames/second
INFO: Non-interlaced/progressive frames.
INFO: Frame size: 352 x 240
INFO: Now generating YUV4MPEG stream.
INFO: VCD default options selected
INFO: Selecting VCD output profile
++ WARN: Assuming norm NTSC
++ WARN: Aspect ratio specifed and no guess possible: assuming 4:3 display aspect!
INFO: Encoding MPEG-1 video to C:/TSCV/seq/Menui.mpv
INFO: Horizontal size: 352 pel
INFO: Vertical size: 240 pel
INFO: Aspect ratio code: 12 = 1:1.1250 (4:3 NTSC for 720x480/352x240 images)
INFO: Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: Bitrate: 1151 KBit/s
INFO: Field order for input: none/progressive
INFO: New Sequence every 2000 Mbytes
INFO: Assuming non-video stream of 0 Kbps
INFO: Search radius: 16
INFO: GOP SIZE RANGE 12 TO 12
INFO: Hor. motion search forces constrained_parameters_flag = 0
INFO: SETTING MMX and EXTENDED MMX for QUANTIZER!
INFO: SETTING EXTENDED MMX for MOTION!
INFO: SETTING MMX for TRANSFORM!
INFO: SETTING EXTENDED MMX for PREDICTION!
INFO: Read from 'C:/TSCV/seq/seq-0000300.jpg' failed: No such file or directory
INFO: No more frames. Stopping.
Please, anybody help?
Thank you very much!
Results 1 to 1 of 1
Converting .MTS to a .JPG image sequence?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 21:14 -
MPV crashing
By SignedupGuest in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 15:38 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 09:06 -
Convert DVD to JPG sequence by any second interval?
By omega_weapon in forum EditingReplies: 3Last Post: 29th Jan 2009, 17:01 -
How to play MPV?
By GangstaRap in forum Newbie / General discussionsReplies: 9Last Post: 1st Dec 2007, 15:18
